Pulled out my 37-650 tonight
OK on the advice. I have already re-capped the whole radio and changed most of the old resistors as well (most were quite high).
I will check the transconductance of both 6F6's to make sure they are close.
The radio sounds good but it would be nice to know that my push-pull stage is really functioning as a push-pull stage!
Herb S.
Pulled out my 37-650 tonight - by hsusmann - 12-26-2013, 12:35 AM
RE: Pulled out my 37-650 tonight - by morzh - 12-26-2013, 11:17 AM
RE: Pulled out my 37-650 tonight - by AI2V - 12-26-2013, 12:14 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-26-2013, 10:46 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 09:44 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 09:55 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:00 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:00 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:04 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:12 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:13 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:18 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 10:22 PM
RE: Pulled out my 37-650 tonight - by morzh - 12-29-2013, 10:30 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-29-2013, 11:37 PM
RE: Pulled out my 37-650 tonight - by Ron Ramirez - 12-30-2013, 01:06 PM
RE: Pulled out my 37-650 tonight - by Joe Rossi - 12-30-2013, 10:01 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-31-2013, 12:40 AM
RE: Pulled out my 37-650 tonight - by BrendaAnnD - 12-31-2013, 02:24 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 12-31-2013, 09:53 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-05-2014, 02:42 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-05-2014, 10:12 PM
RE: Pulled out my 37-650 tonight - by codefox1 - 01-05-2014, 11:28 PM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-06-2014, 09:40 AM
RE: Pulled out my 37-650 tonight - by Eric T - 01-10-2014, 08:04 PM
RE: Pulled out my 37-650 tonight - by Jamie - 01-11-2014, 10:52 AM
RE: Pulled out my 37-650 tonight - by hsusmann - 01-11-2014, 11:57 AM
Philco 91 Tuning Condenser
There are currently 9345 online users. [Complete List]
» 1 Member(s) | 9344 Guest(s)
