42-400 decals
Finishing on a 42-400 and have ordered the decals from Radio Daze but have found they do not have the correct 'TREBLE' and 'BASS" as they are all horizontal and the 400 uses the far left and right thumbwheels solely for bass and treble and the labels are vertical. Any know of any other source?
If not I will cut the horizontal ones apart and make them vertical.
Trouble is also an arrow pointing to higher levels on both. Guessing i may have to mask off the old one and paint as I've done to the trim around the escutcheon.
42-400 decals - by jeffgniffke - 01-06-2014, 01:45 PM
RE: 42-400 decals - by sigpoggy - 09-25-2016, 07:55 PM
RE: 42-400 decals - by klondike98 - 09-25-2016, 09:08 PM
RE: 42-400 decals - by klondike98 - 09-26-2016, 11:15 AM
