48-460 antenna replacement
So, aside from the possible questionable suitability of using silicones, what are other suitable choices I can use?
Did I gather 'hot glue' is an alternative?
Any other suggestions?
John
48-460 antenna replacement - by phly guy - 05-21-2008, 01:48 AM
[No subject] - by Texasrocker - 05-23-2008, 02:41 AM
[No subject] - by phly guy - 05-23-2008, 04:49 PM
[No subject] - by Ron Ramirez - 05-23-2008, 07:28 PM
[No subject] - by Texasrocker - 05-25-2008, 03:01 AM
[No subject] - by Ron Ramirez - 05-25-2008, 12:14 PM
[No subject] - by phly guy - 05-27-2008, 12:57 PM
[No subject] - by exray - 05-27-2008, 01:33 PM
[No subject] - by phly guy - 05-28-2008, 01:43 AM
[No subject] - by Texasrocker - 05-28-2008, 02:17 AM
[No subject] - by exray - 05-28-2008, 06:07 AM
There are currently 10448 online users. [Complete List]
» 2 Member(s) | 10446 Guest(s)
