Philco AC/DC Pilot Lamps
If the radio uses (any) 6 volt tubes: 250mA
Screw base: 46
Bayonet base: 44
If the radio uses (any) 12 volt tubes: 150mA
Bayonet base: 47, 1847
Philco AC/DC Pilot Lamps - by Joeztech - 01-07-2014, 12:19 PM
RE: Philco AC/DC Pilot Lamps - by BrendaAnnD - 01-07-2014, 12:56 PM
RE: Philco AC/DC Pilot Lamps - by klondike98 - 01-07-2014, 01:15 PM
RE: Philco AC/DC Pilot Lamps - by Joeztech - 01-07-2014, 02:37 PM
RE: Philco AC/DC Pilot Lamps - by klondike98 - 01-07-2014, 02:42 PM
There are currently 9663 online users. [Complete List]
» 1 Member(s) | 9662 Guest(s)
