Philco 70 Resistor
Thanks Steve. That solves the problem. Your schematic is not from Nostalgia Air which is what I was using. Where did you obtain the schematic? If you have the parts identification list that goes with this schematic, I would greatly appreciate that.
Thanks again
Dan Koczur
Philco 70 Resistor - by dkoczur - 01-07-2014, 02:20 PM
RE: Philco 70 Resistor - by Steve Davis - 01-07-2014, 03:49 PM
RE: Philco 70 Resistor - by dkoczur - 01-07-2014, 04:03 PM
RE: Philco 70 Resistor - by Steve Davis - 01-07-2014, 05:14 PM
RE: Philco 70 Resistor - by klondike98 - 01-07-2014, 05:15 PM
Philco 91 Tuning Condenser
There are currently 8960 online users. [Complete List]
» 1 Member(s) | 8959 Guest(s)
