Philco 70 Resistor
You can get clear schematic and parts listing info from Chuck Schwark at http://www.philcorepairbench.com/schematics.htm
In the meantime see: http://www.philcoradio.com/tech/images/70a.jpg for early models and http://www.philcoradio.com/tech/images/70b.jpg for later ones.
Philco 70 Resistor - by dkoczur - 01-07-2014, 02:20 PM
RE: Philco 70 Resistor - by Steve Davis - 01-07-2014, 03:49 PM
RE: Philco 70 Resistor - by dkoczur - 01-07-2014, 04:03 PM
RE: Philco 70 Resistor - by Steve Davis - 01-07-2014, 05:14 PM
RE: Philco 70 Resistor - by klondike98 - 01-07-2014, 05:15 PM
