70 speaker
Philco 70 is as simple as it gets with superherts.
It is one of those "milestone" radios with Philco, this is why I got it, together with 20 and 90.
When done with it don't expect a stellar performance, but it will sound OK.
70 speaker - by TV MAN - 01-08-2014, 12:06 PM
RE: 70 speaker - by Phlogiston - 01-08-2014, 03:32 PM
RE: 70 speaker - by morzh - 01-08-2014, 04:23 PM
RE: 70 speaker - by TV MAN - 01-09-2014, 12:03 PM
RE: 70 speaker - by morzh - 01-09-2014, 12:12 PM
RE: 70 speaker - by Steve D - 01-10-2014, 09:20 AM
RE: 70 speaker - by TV MAN - 03-06-2014, 02:27 PM
RE: 70 speaker - by morzh - 03-06-2014, 02:53 PM
RE: 70 speaker - by TV MAN - 03-07-2014, 02:29 PM
RE: 70 speaker - by morzh - 03-07-2014, 02:34 PM
There are currently 6820 online users. [Complete List]
» 4 Member(s) | 6816 Guest(s)
AvatarAvatarAvatarAvatar
