39-7: The Saga continues
#32
This is true. Family "graveyards" are literally everywhere. I've never seen a "public" graveyard ala western countries. I'm not even sure where they do logging, with the exception of areas where they are in the process of erecting a new city. That's one of the most fascinating things about the ROK: instant cities! In the time I've lived here, I've seen several places go from being rice fields and light forestation to being cities of 500,000-1,000,000 inhabitants in the space of a year or two's time. It's interesting to watch as you drive by an area from week to week.
39-7: The Saga continues - by BrendaAnnD - 01-03-2014, 12:10 PM
RE: 39-7: The Saga continues - by PhilcoMike - 01-03-2014, 12:43 PM
RE: 39-7: The Saga continues - by morzh - 01-03-2014, 09:12 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-04-2014, 10:56 AM
RE: 39-7: The Saga continues - by TA Forbes - 01-04-2014, 11:58 AM
RE: 39-7: The Saga continues - by morzh - 01-04-2014, 04:51 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-04-2014, 06:04 PM
RE: 39-7: The Saga continues - by hsusmann - 01-04-2014, 06:42 PM
RE: 39-7: The Saga continues - by morzh - 01-04-2014, 09:12 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-04-2014, 11:45 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-05-2014, 10:18 AM
RE: 39-7: The Saga continues - by w4rtc - 01-05-2014, 12:31 PM
RE: 39-7: The Saga continues - by morzh - 01-05-2014, 01:02 PM
RE: 39-7: The Saga continues - by hsusmann - 01-05-2014, 02:33 PM
RE: 39-7: The Saga continues - by Warren - 01-05-2014, 02:38 PM
RE: 39-7: The Saga continues - by Joeztech - 01-05-2014, 05:41 PM
RE: 39-7: The Saga continues - by Eric Adams - 01-05-2014, 05:50 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-06-2014, 12:07 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-06-2014, 12:25 PM
RE: 39-7: The Saga continues - by Joe Rossi - 01-06-2014, 05:35 PM
RE: 39-7: The Saga continues - by Eric Adams - 01-06-2014, 06:50 PM
RE: 39-7: The Saga continues - by hsusmann - 01-06-2014, 06:58 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-07-2014, 11:53 AM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 08:52 AM
RE: 39-7: The Saga continues - by morzh - 01-08-2014, 02:38 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 03:27 PM
RE: 39-7: The Saga continues - by morzh - 01-08-2014, 04:25 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 07:17 PM
RE: 39-7: The Saga continues - by morzh - 01-08-2014, 07:31 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 09:12 PM
RE: 39-7: The Saga continues - by TA Forbes - 01-08-2014, 09:24 PM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-08-2014, 10:15 PM
RE: 39-7: The Saga continues - by jontz - 01-09-2014, 07:54 AM
RE: 39-7: The Saga continues - by BrendaAnnD - 01-09-2014, 10:41 AM
Philco 91 Tuning Condenser
