Philco RF cans to chassis connection
What I need is a copper bar, placed between the coil holder and the chassis sing the flared can edge as a fulcrum. Times 4.
Philco RF cans to chassis connection - by morzh - 01-08-2014, 05:57 PM
RE: Philco RF cans to chassis connection - by morzh - 01-08-2014, 10:46 PM
Philco 91 Tuning Condenser
