Cleaning and Polishing Bakelite knobs
Cool Eric! Trouble with the big consoles it is not easy to remove the thumbwheels is not a simple task so have to do it in place.
RE: Cleaning and Polishing Bakelite knobs - by jeffgniffke - 01-09-2014, 12:47 PM
Eico 232 VTVM Schematic
There are currently 10012 online users. [Complete List]
» 1 Member(s) | 10011 Guest(s)
