Model 20
Greg
Actually speaking of bias, whether connected to Chassis or to B the centertap will be sufficiently negative towards the cahodes (filaments) as, as you cn see, the filaments connect to the C voltage which is biased towards B using the 1-2 section of the big resistor #26 which is 1.4kOhm. The output tubes being the heaviest drawers will likely self bias enough for the grids to be negative. However you are right to reconnect the centertap to B as this is what is required by the sch.
Which brings up this question: is the mentioned resistor 1.4k as required?
Model 20 - by gregb - 01-07-2014, 12:06 PM
RE: Model 20 - by Mondial - 01-07-2014, 04:46 PM
RE: Model 20 - by gregb - 01-07-2014, 05:24 PM
RE: Model 20 - by gregb - 01-08-2014, 07:08 PM
RE: Model 20 - by Mondial - 01-08-2014, 10:13 PM
RE: Model 20 - by gregb - 01-08-2014, 10:55 PM
RE: Model 20 - by gregb - 01-08-2014, 11:46 PM
RE: Model 20 - by morzh - 01-09-2014, 12:05 AM
RE: Model 20 - by morzh - 01-09-2014, 12:09 AM
RE: Model 20 - by gregb - 01-09-2014, 12:18 AM
RE: Model 20 - by morzh - 01-09-2014, 12:17 PM
RE: Model 20 - by gregb - 01-09-2014, 02:15 PM
RE: Model 20 - by morzh - 01-09-2014, 03:33 PM
RE: Model 20 - by gregb - 01-09-2014, 03:44 PM
RE: Model 20 - by gregb - 01-09-2014, 03:46 PM
RE: Model 20 - by morzh - 01-09-2014, 07:04 PM
RE: Model 20 - by gregb - 01-11-2014, 12:57 AM
RE: Model 20 - by morzh - 01-11-2014, 11:30 AM
RE: Model 20 - by BrendaAnnD - 01-11-2014, 06:07 PM
RE: Model 20 - by morzh - 01-11-2014, 06:51 PM
RE: Model 20 - by gregb - 01-11-2014, 09:40 PM
Philco 91 Tuning Condenser
