Issue with Philco 118MX
I'd put that bad 42 tube back in to see if the problem comes back.
Sometimes you get fooled.
Chances are that was it!
I will have to remember this one for the future.
Thanks for the saga!
Herb S.
Issue with Philco 118MX - by Jamie - 01-08-2014, 06:22 PM
RE: Issue with Philco 118MX - by morzh - 01-08-2014, 06:38 PM
RE: Issue with Philco 118MX - by Jamie - 01-08-2014, 06:44 PM
RE: Issue with Philco 118MX - by morzh - 01-08-2014, 06:47 PM
RE: Issue with Philco 118MX - by Jamie - 01-08-2014, 06:51 PM
RE: Issue with Philco 118MX - by Jamie - 01-08-2014, 07:14 PM
RE: Issue with Philco 118MX - by morzh - 01-08-2014, 07:37 PM
RE: Issue with Philco 118MX - by jerryhawthorne - 01-09-2014, 04:53 PM
RE: Issue with Philco 118MX - by Jamie - 01-09-2014, 04:56 PM
RE: Issue with Philco 118MX - by hsusmann - 01-09-2014, 05:22 PM
RE: Issue with Philco 118MX - by Jamie - 01-09-2014, 05:46 PM
RE: Issue with Philco 118MX - by hsusmann - 01-09-2014, 05:51 PM
RE: Issue with Philco 118MX - by Jamie - 01-09-2014, 05:54 PM
RE: Issue with Philco 118MX - by codefox1 - 01-09-2014, 06:35 PM
RE: Issue with Philco 118MX - by hsusmann - 01-09-2014, 06:49 PM
RE: Issue with Philco 118MX - by morzh - 01-09-2014, 07:09 PM
Philco 91 Tuning Condenser
There are currently 10445 online users. [Complete List]
» 2 Member(s) | 10443 Guest(s)
