Issue with Philco 118MX
Puhpow,
OK sounds like you've got it then!
I wonder what is going on with the tube then?
Is your tube tester a transconductance measuring type
or just emissions? Did it pass the shorts test and gas test?
Herb S.
Issue with Philco 118MX - by Jamie - 01-08-2014, 06:22 PM
RE: Issue with Philco 118MX - by morzh - 01-08-2014, 06:38 PM
RE: Issue with Philco 118MX - by Jamie - 01-08-2014, 06:44 PM
RE: Issue with Philco 118MX - by morzh - 01-08-2014, 06:47 PM
RE: Issue with Philco 118MX - by Jamie - 01-08-2014, 06:51 PM
RE: Issue with Philco 118MX - by Jamie - 01-08-2014, 07:14 PM
RE: Issue with Philco 118MX - by morzh - 01-08-2014, 07:37 PM
RE: Issue with Philco 118MX - by jerryhawthorne - 01-09-2014, 04:53 PM
RE: Issue with Philco 118MX - by Jamie - 01-09-2014, 04:56 PM
RE: Issue with Philco 118MX - by hsusmann - 01-09-2014, 05:22 PM
RE: Issue with Philco 118MX - by Jamie - 01-09-2014, 05:46 PM
RE: Issue with Philco 118MX - by hsusmann - 01-09-2014, 05:51 PM
RE: Issue with Philco 118MX - by Jamie - 01-09-2014, 05:54 PM
RE: Issue with Philco 118MX - by codefox1 - 01-09-2014, 06:35 PM
RE: Issue with Philco 118MX - by hsusmann - 01-09-2014, 06:49 PM
RE: Issue with Philco 118MX - by morzh - 01-09-2014, 07:09 PM
Philco 91 Tuning Condenser
There are currently 9464 online users. [Complete List]
» 3 Member(s) | 9461 Guest(s)
