Model 38-12 antenna details?
The 38-12 never had a built-in antenna. Instead, there are (or should be) two wires protruding from the back of the chassis - one for a longwire antenna, and the other for ground. These sets, like all 1939 and older Philcos, were intended to be used with a long outside wire as an antenna - 50 to 100 feet long and as high as possible. 20 feet strung along the baseboard of the room the radio is in is better than nothing, but it works better if it is higher up.
Model 38-12 antenna details? - by Philco38-12 - 01-09-2014, 02:58 PM
RE: Model 38-12 antenna details? - by Ron Ramirez - 01-09-2014, 06:23 PM
RE: Model 38-12 antenna details? - by WyTex - 01-10-2014, 10:03 AM
RE: Model 38-12 antenna details? - by hsusmann - 01-10-2014, 10:50 AM
Philco 91 Tuning Condenser
There are currently 8700 online users. [Complete List]
» 3 Member(s) | 8697 Guest(s)
