38-62 - can't get the one station I want to hear!
Don't want to butt in here, but could the AVC possibly be choking the station
down since it is so close? Probably extra-strong signal getting to the radio.
Jim
RE: 38-62 - can't get the one station I want to hear! - by brownie45 - 01-10-2014, 02:17 PM
Philco 91 Tuning Condenser
