Philco 37-89 Speaker.
Greetings all,
I've a Philco 37-89 with a speaker so bad off, it will need replacement. It looks as though 80 percent of the paper cone is gone to that takes care of any possible repairs.
Two questions. First, are there any other models with compatible speakers that will work out for this old set? Second, does anyone have one they're willing to part with?
With regards to the second question, I will post in the wanted section once I find out which speaker or speaker models will work out.
73 de,
Gary/N9VU
Philco 37-89 Speaker. - by n9vu - 05-31-2008, 08:13 PM
[No subject] - by BDM - 06-01-2008, 04:38 AM
[No subject] - by n9vu - 06-01-2008, 07:36 AM
[No subject] - by Ron Ramirez - 06-01-2008, 11:22 AM
[No subject] - by n9vu - 06-01-2008, 02:15 PM
There are currently 8487 online users. [Complete List]
» 1 Member(s) | 8486 Guest(s)
