Any idea on this model?
Hi,
Just a curious question on this radio.
So what do the numbers on the bottom of the scale mean?
(180-545).
Is this some kind of long wave band like they used to
have in Europe?
Or do the numbers mean something else entirely!
Just wondering...
Herb S.
Any idea on this model? - by WyTex - 01-10-2014, 09:33 AM
RE: Any idea on this model? - by Ron Ramirez - 01-10-2014, 12:45 PM
RE: Any idea on this model? - by WyTex - 01-10-2014, 04:23 PM
RE: Any idea on this model? - by klondike98 - 01-10-2014, 04:34 PM
RE: Any idea on this model? - by WyTex - 01-10-2014, 04:48 PM
RE: Any idea on this model? - by Ron Ramirez - 01-10-2014, 04:49 PM
RE: Any idea on this model? - by morzh - 01-10-2014, 05:28 PM
RE: Any idea on this model? - by WyTex - 01-10-2014, 05:31 PM
RE: Any idea on this model? - by Ron Ramirez - 01-10-2014, 05:39 PM
RE: Any idea on this model? - by WyTex - 01-10-2014, 06:41 PM
RE: Any idea on this model? - by Eric T - 01-10-2014, 10:54 PM
RE: Any idea on this model? - by hsusmann - 01-10-2014, 11:30 PM
RE: Any idea on this model? - by jontz - 01-10-2014, 11:34 PM
RE: Any idea on this model? - by hsusmann - 01-10-2014, 11:41 PM
RE: Any idea on this model? - by JimZ - 01-11-2014, 10:18 AM
RE: Any idea on this model? - by Jamie - 01-11-2014, 10:45 AM
RE: Any idea on this model? - by Ron Ramirez - 01-11-2014, 03:19 PM
RE: Any idea on this model? - by klondike98 - 01-11-2014, 03:28 PM
RE: Any idea on this model? - by Joe Rossi - 01-11-2014, 05:27 PM
RE: Any idea on this model? - by WyTex - 01-11-2014, 10:19 PM
RE: Any idea on this model? - by Ron Ramirez - 01-11-2014, 10:44 PM
RE: Any idea on this model? - by Arran - 01-12-2014, 02:20 AM
RE: Any idea on this model? - by Joeztech - 01-12-2014, 12:20 PM
RE: Any idea on this model? - by Paul Philco322 - 01-12-2014, 03:21 PM
RE: Any idea on this model? - by LASJayhawk - 01-12-2014, 09:01 PM
There are currently 8812 online users. [Complete List]
» 3 Member(s) | 8809 Guest(s)
