Model 20
Yes, if you remove the transformer the wires will be underneath.
the speaker was repaired, I think - you could see the two insulators for the voice coil solder posts on the left of the transformer. I am not sure what happened but if they decided to connect short voice coil wires directly to the rigid transformer output ones, then no wonder the speaker sounds more rigid than it should.
Model 20 - by gregb - 01-07-2014, 12:06 PM
RE: Model 20 - by Mondial - 01-07-2014, 04:46 PM
RE: Model 20 - by gregb - 01-07-2014, 05:24 PM
RE: Model 20 - by gregb - 01-08-2014, 07:08 PM
RE: Model 20 - by Mondial - 01-08-2014, 10:13 PM
RE: Model 20 - by gregb - 01-08-2014, 10:55 PM
RE: Model 20 - by gregb - 01-08-2014, 11:46 PM
RE: Model 20 - by morzh - 01-09-2014, 12:05 AM
RE: Model 20 - by morzh - 01-09-2014, 12:09 AM
RE: Model 20 - by gregb - 01-09-2014, 12:18 AM
RE: Model 20 - by morzh - 01-09-2014, 12:17 PM
RE: Model 20 - by gregb - 01-09-2014, 02:15 PM
RE: Model 20 - by morzh - 01-09-2014, 03:33 PM
RE: Model 20 - by gregb - 01-09-2014, 03:44 PM
RE: Model 20 - by gregb - 01-09-2014, 03:46 PM
RE: Model 20 - by morzh - 01-09-2014, 07:04 PM
RE: Model 20 - by gregb - 01-11-2014, 12:57 AM
RE: Model 20 - by morzh - 01-11-2014, 11:30 AM
RE: Model 20 - by BrendaAnnD - 01-11-2014, 06:07 PM
RE: Model 20 - by morzh - 01-11-2014, 06:51 PM
RE: Model 20 - by gregb - 01-11-2014, 09:40 PM
Philco 91 Tuning Condenser
There are currently 5113 online users. [Complete List]
» 2 Member(s) | 5111 Guest(s)
