Model 20
I have now taken it apart and from what I can see it is all original. The solder looks just as old as every other connection in the set and everything has that factory look to it. All of the connections to the transformer are directly below it and I am sure all original. It is a Canadian made radio so possible we Canucks did things a little different back in the day, as will still do.
Gregb
Model 20 - by gregb - 01-07-2014, 12:06 PM
RE: Model 20 - by Mondial - 01-07-2014, 04:46 PM
RE: Model 20 - by gregb - 01-07-2014, 05:24 PM
RE: Model 20 - by gregb - 01-08-2014, 07:08 PM
RE: Model 20 - by Mondial - 01-08-2014, 10:13 PM
RE: Model 20 - by gregb - 01-08-2014, 10:55 PM
RE: Model 20 - by gregb - 01-08-2014, 11:46 PM
RE: Model 20 - by morzh - 01-09-2014, 12:05 AM
RE: Model 20 - by morzh - 01-09-2014, 12:09 AM
RE: Model 20 - by gregb - 01-09-2014, 12:18 AM
RE: Model 20 - by morzh - 01-09-2014, 12:17 PM
RE: Model 20 - by gregb - 01-09-2014, 02:15 PM
RE: Model 20 - by morzh - 01-09-2014, 03:33 PM
RE: Model 20 - by gregb - 01-09-2014, 03:44 PM
RE: Model 20 - by gregb - 01-09-2014, 03:46 PM
RE: Model 20 - by morzh - 01-09-2014, 07:04 PM
RE: Model 20 - by gregb - 01-11-2014, 12:57 AM
RE: Model 20 - by morzh - 01-11-2014, 11:30 AM
RE: Model 20 - by BrendaAnnD - 01-11-2014, 06:07 PM
RE: Model 20 - by morzh - 01-11-2014, 06:51 PM
RE: Model 20 - by gregb - 01-11-2014, 09:40 PM
There are currently 8826 online users. [Complete List]
» 3 Member(s) | 8823 Guest(s)
