37-610 Voltage measurements
DUH!!!
Having looked at the Riders Vs. Philco service info, it appears that I suspected a really high plate voltage on the 6Q7... Riders appears to spec "125"; Philco appears to spec 175. Conclusion: at 208 Volts it is just high, not REALLY HIGH... (AND would no doubt look even closer if I had the 1000 Ohm/Volt Philco 025 test instrument). Would someone look at their paperwork and confirm? Now onto recapping, just waiting for my recap kit to come in. Stay tuned.
37-610 Voltage measurements - by Arizona_steve - 01-05-2014, 01:58 AM
RE: 37-610 Voltage measurements - by BrendaAnnD - 01-05-2014, 10:35 AM
RE: 37-610 Voltage measurements - by klondike98 - 01-05-2014, 10:36 AM
RE: 37-610 Voltage measurements - by Arizona_steve - 01-12-2014, 12:32 AM
RE: 37-610 Voltage measurements - by morzh - 01-12-2014, 12:44 AM
Philco 91 Tuning Condenser
There are currently 10385 online users. [Complete List]
» 2 Member(s) | 10383 Guest(s)
