HELP! Is this a Philco?
Well, there are no photos of the actual changer there, but just by going by what I can see and the 45 spindle, I am pretty sure that changer is a Voice of Music design.
HELP! Is this a Philco? - by JHart - 01-11-2014, 10:59 PM
RE: HELP! Is this a Philco? - by morzh - 01-11-2014, 11:03 PM
RE: HELP! Is this a Philco? - by morzh - 01-11-2014, 11:57 PM
RE: HELP! Is this a Philco? - by Jayce - 01-12-2014, 01:32 AM
RE: HELP! Is this a Philco? - by Arran - 01-12-2014, 02:02 AM
RE: HELP! Is this a Philco? - by JHart - 01-12-2014, 02:39 AM
RE: HELP! Is this a Philco? - by Jayce - 01-12-2014, 12:56 PM
RE: HELP! Is this a Philco? - by Arran - 01-12-2014, 02:54 PM
RE: HELP! Is this a Philco? - by JHart - 01-12-2014, 03:01 PM
Philco 91 Tuning Condenser
There are currently 6253 online users. [Complete List]
» 3 Member(s) | 6250 Guest(s)
