Capasitor block replacements, philco model 20
It should not be a problem re stuffing them into a can. They only call for 1.0 and 1.5mfd.
What is the benefit in using non electrolytic ? I think that's really what I am trying to find out.
Thanks phlogiston
There are currently 8690 online users. [Complete List]
» 2 Member(s) | 8688 Guest(s)
