Philco Station setter info
Hi guys,
I finally received the station setter.
Looks like it had not been altered. It has installed a 7A6 rectifier (instead of the 7Z4) and the 7A8
I see the 7A6 is wired like the 7Z4 would be.
Bad news is that there is a coil missing. As you can see on the other photo of the setter, there is a square coil mounted to the box, and the two caps are connected to the center tap of it.
I am not sure what the purpose of this coil would be looking at the diagram, shown in the red box.
Hopefully this is something that can be substituted. At least I know what the physical size of this coil is.
What part of the circuit is this coil for?
Thanks for your continued help on this box, as I'd like to recap it (restuff) and get it going.
Regards,
Gary.
[Image: http://antiqueradios.com/gallery/d/77921...erdiag.JPG]
[Image: http://antiqueradios.com/gallery/d/77929-1/coil.jpg]
[Image: http://antiqueradios.com/gallery/d/77927...r1_001.JPG]
[Image: http://antiqueradios.com/gallery/d/77925...r2_001.JPG]
Philco Station setter info - by gary rabbitt - 05-18-2008, 02:27 AM
[No subject] - by Ron Ramirez - 05-19-2008, 11:25 PM
[No subject] - by Chuck Schwark - 05-20-2008, 09:17 AM
[No subject] - by Ron Ramirez - 05-20-2008, 06:26 PM
[No subject] - by Chuck Schwark - 05-20-2008, 07:33 PM
[No subject] - by exray - 05-20-2008, 09:09 PM
[No subject] - by gary rabbitt - 05-20-2008, 11:35 PM
[No subject] - by Ron Ramirez - 05-21-2008, 06:46 AM
[No subject] - by Chuck Schwark - 05-21-2008, 12:57 PM
[No subject] - by Chuck Schwark - 05-22-2008, 04:15 PM
[No subject] - by gary rabbitt - 05-27-2008, 12:33 AM
[No subject] - by Chuck Schwark - 05-27-2008, 10:48 AM
[No subject] - by gary rabbitt - 06-03-2008, 06:13 PM
[No subject] - by Chuck Schwark - 06-03-2008, 10:59 PM
[No subject] - by gary rabbitt - 06-04-2008, 02:37 AM
There are currently 9963 online users. [Complete List]
» 2 Member(s) | 9961 Guest(s)
