Capasitor block replacements, philco model 20
I personally went with original value 630v caps when I rebuilt mine, with one exception. One cap was rated .13 mfd, and not easily available in that value. I went with a .15 mfd cap there with no issues. Take care, Gary
Philco 91 Tuning Condenser
There are currently 8060 online users. [Complete List]
» 2 Member(s) | 8058 Guest(s)
