38-62 - can't get the one station I want to hear!
If I tune the dial further below 1210 it usually comes back to life. I can then hear the 1210 station but never 1440.
RE: 38-62 - can't get the one station I want to hear! - by WyTex - 01-13-2014, 02:25 PM
Philco 91 Tuning Condenser
There are currently 9814 online users. [Complete List]
» 1 Member(s) | 9813 Guest(s)
