Capasitor block replacements, philco model 20
If you need a .13uf and you can't find one of that value, can you not just connect them in parallel? So have a .10 and a .03 ?
Also is there a problem with going too high on the voltage rating?
There are currently 8783 online users. [Complete List]
» 3 Member(s) | 8780 Guest(s)
