Threads: 10
City: Columbia, SC
Thanks morzh, that's exactly what I wanted to hear ;) Between a reel of 30 and 36 or 38 I think I have it covered.
Getting closer now. Tonight I'm going to try hacking into the electrolytic cans, which sound to still be almost filled with electrolyte. Expecting a mess..
RE: Model 89 Cathedral - by skyscraper - 01-13-2014, 07:58 PM
Users browsing this thread: 40 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
