1936 60 alignment issues
Keith
1. have you measured your tubes?
2. Even if you did, have you made sure your pentagrid oscillates across the whole band?
1936 60 alignment issues - by ipwizard - 01-13-2014, 11:28 PM
RE: 1936 60 alignment issues - by morzh - 01-14-2014, 12:00 AM
RE: 1936 60 alignment issues - by BrendaAnnD - 01-14-2014, 12:46 AM
RE: 1936 60 alignment issues - by BrendaAnnD - 01-14-2014, 12:49 AM
RE: 1936 60 alignment issues - by Radioroslyn - 01-14-2014, 06:09 PM
RE: 1936 60 alignment issues - by ipwizard - 01-17-2014, 12:13 AM
RE: 1936 60 alignment issues - by Mondial - 01-17-2014, 12:35 AM
Philco 91 Tuning Condenser
There are currently 9339 online users. [Complete List]
» 1 Member(s) | 9338 Guest(s)
