Evapo-Rust cleaning the chassis
I try not to use any of that stuff. It is OK at dissolving rust. It is GREAT at removing the original plating. For one, I want the original plating in place. For two, if you remove the plating the chassis is going to rust (more) unless you paint it which make it even less original. I think (your results may vary) that selective placement of navel jelly on very rusty spots is ok. Then seal those spots ONLY.
Evapo-Rust cleaning the chassis - by TV MAN - 01-14-2014, 12:19 PM
RE: Evapo-Rust cleaning the chassis - by morzh - 01-14-2014, 12:44 PM
RE: Evapo-Rust cleaning the chassis - by Phlogiston - 01-14-2014, 02:35 PM
RE: Evapo-Rust cleaning the chassis - by codefox1 - 01-14-2014, 03:11 PM
RE: Evapo-Rust cleaning the chassis - by Arran - 01-15-2014, 04:30 AM
RE: Evapo-Rust cleaning the chassis - by morzh - 01-15-2014, 11:37 PM
RE: Evapo-Rust cleaning the chassis - by jontz - 01-16-2014, 07:37 AM
RE: Evapo-Rust cleaning the chassis - by TV MAN - 01-16-2014, 10:22 PM
RE: Evapo-Rust cleaning the chassis - by Jamesm - 01-24-2014, 10:31 PM
Philco 91 Tuning Condenser
There are currently 9278 online users. [Complete List]
» 1 Member(s) | 9277 Guest(s)
