42-1008 SHORTWAVE BAND SILENT
Success!!, the cleaning (again) of the switch, and cleaning the inside of the antenna terminal area as well as tightening the screws where the antenna wires attach, and SW came to life in a big way. Many thanks to all of you for your helpful suggestions. If I went ahead and tried to remove the oscillator coils as I had originally planned, I would have ruined everything. Now on to the BOL phono.
42-1008 SHORTWAVE BAND SILENT - by davidff - 12-30-2013, 09:30 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 12-30-2013, 09:58 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by hsusmann - 12-30-2013, 10:18 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-02-2014, 10:21 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by BrendaAnnD - 01-02-2014, 11:00 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-05-2014, 03:49 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-06-2014, 09:59 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-08-2014, 08:36 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-08-2014, 08:42 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-08-2014, 08:53 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-10-2014, 07:52 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by Jamie - 01-11-2014, 10:59 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-11-2014, 11:32 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-12-2014, 03:07 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-12-2014, 06:11 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by codefox1 - 01-14-2014, 03:18 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by davidff - 01-15-2014, 09:14 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 09:45 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by hsusmann - 01-15-2014, 01:52 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 02:30 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 03:40 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by hsusmann - 01-15-2014, 04:19 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by morzh - 01-15-2014, 04:41 PM
RE: 42-1008 SHORTWAVE BAND SILENT - by Eric T - 01-18-2014, 01:21 AM
RE: 42-1008 SHORTWAVE BAND SILENT - by BrendaAnnD - 01-18-2014, 03:09 AM
Philco 91 Tuning Condenser
There are currently 9092 online users. [Complete List]
» 1 Member(s) | 9091 Guest(s)
