Philco 42-PT-96
i reacapped the set only the cap on he tunning cap and a .2 cab in the chassis i dident replace because the person i ordered the caps off dident send them,ok before i recapped the set i could only get one station CBC ,now i can not get any thing only a hum,this set has 4 locktals and 2 octal,i turn the set on and only 2 tubes light up the 35Z3 and the 50L6,the 7A8,7B7,and 7C6 dont light up could this be the problem?
Philco 42-PT-96 - by Guest - 11-27-2005, 12:48 PM
RE: Philco 42-PT-96 - by Marko - 03-26-2018, 11:49 AM
RE: Philco 42-PT-96 - by Radioroslyn - 03-26-2018, 12:23 PM
RE: Philco 42-PT-96 - by Marko - 03-26-2018, 12:37 PM
[No subject] - by zenith82 - 11-27-2005, 02:47 PM
