Tuned radio hum
That could be in my case though in the new part of my basement I did all of the electrical so I know its all good but the rest of the basement looks like it was done with economy in mind and hard to say. I do plan to reno the rest of it and rewire and insulate so will keep a close eye out for wiring errors like you describe.
Gregb
Tuned radio hum - by morzh - 01-08-2014, 03:11 PM
RE: Tuned radio hum - by BrendaAnnD - 01-08-2014, 03:30 PM
RE: Tuned radio hum - by morzh - 01-08-2014, 03:38 PM
RE: Tuned radio hum - by LASJayhawk - 01-08-2014, 05:16 PM
RE: Tuned radio hum - by Chuck Schwark - 01-08-2014, 05:39 PM
RE: Tuned radio hum - by morzh - 01-08-2014, 05:53 PM
RE: Tuned radio hum - by BrendaAnnD - 01-08-2014, 09:23 PM
RE: Tuned radio hum - by morzh - 01-09-2014, 12:09 PM
RE: Tuned radio hum - by TA Forbes - 01-11-2014, 11:49 AM
RE: Tuned radio hum - by gregb - 01-16-2014, 02:11 PM
RE: Tuned radio hum - by morzh - 01-16-2014, 02:26 PM
RE: Tuned radio hum - by gregb - 01-16-2014, 05:12 PM
RE: Tuned radio hum - by morzh - 01-16-2014, 05:33 PM
RE: Tuned radio hum - by gregb - 01-16-2014, 06:05 PM
RE: Tuned radio hum - by David - 01-16-2014, 07:07 PM
RE: Tuned radio hum - by morzh - 01-16-2014, 08:59 PM
RE: Tuned radio hum - by David - 01-16-2014, 09:13 PM
Philco 91 Tuning Condenser
There are currently 10176 online users. [Complete List]
» 2 Member(s) | 10174 Guest(s)
