Capacitor question.
Well, my bad. IT IS electrolyte, after all. I have never used radials, only axials,
and this one has different markings -there is a narrow silver line going along the length of the cap with a "-" marks but without an arrow. Rightfully so, as with both leads coming from the same side arrow would be irrelevant. Also the negative lead is shorter.Sorry guys for taking your time.
Capacitor question. - by fields 100 - 01-16-2014, 06:13 PM
RE: Capacitor question. - by morzh - 01-16-2014, 06:51 PM
RE: Capacitor question. - by Phlogiston - 01-16-2014, 07:10 PM
RE: Capacitor question. - by fields 100 - 01-16-2014, 07:14 PM
RE: Capacitor question. - by fields 100 - 01-16-2014, 07:59 PM
RE: Capacitor question. - by morzh - 01-16-2014, 08:58 PM
Philco 91 Tuning Condenser
There are currently 10072 online users. [Complete List]
» 3 Member(s) | 10069 Guest(s)
