Evapo-Rust cleaning the chassis
I think you guys are right about the plating. Looks like there was some kind of coating on this chassis that Evapo took off. This thing is a basket case of sorts anyway, and has been my 'tester' for different things. I will probably end up stripping it and fogging it with some kind of attractive paint. Might dip it and see what happens. Still need to rebuild - or build it. But, back to the Evapo - this might not be much of an issue if the chassis isnt plated, like the older Philcos. Ah, now I know how to spell Naval (navel??) Thanks morzh! lol
Tim
Evapo-Rust cleaning the chassis - by TV MAN - 01-14-2014, 12:19 PM
RE: Evapo-Rust cleaning the chassis - by morzh - 01-14-2014, 12:44 PM
RE: Evapo-Rust cleaning the chassis - by codefox1 - 01-14-2014, 03:11 PM
RE: Evapo-Rust cleaning the chassis - by Arran - 01-15-2014, 04:30 AM
RE: Evapo-Rust cleaning the chassis - by morzh - 01-15-2014, 11:37 PM
RE: Evapo-Rust cleaning the chassis - by jontz - 01-16-2014, 07:37 AM
RE: Evapo-Rust cleaning the chassis - by TV MAN - 01-16-2014, 10:22 PM
RE: Evapo-Rust cleaning the chassis - by Jamesm - 01-24-2014, 10:31 PM
Philco 91 Tuning Condenser
