philco 84 restoration grill cloth question
Here is the pic of the grill cloth I want:
It is the 70/90 from the new grill cloth post by Ron.
I got the chevron and it is darker than mine but It is too nice not to use it on my 37-640 floor model.
RE: philco 84 restoration grill cloth question - by OldRestorer - 01-17-2014, 11:01 AM
Philco 91 Tuning Condenser
There are currently 10152 online users. [Complete List]
» 3 Member(s) | 10149 Guest(s)
