Are 40-90 and 38-12TT the same radio?
No, they are not the same internally (although the cabinet is the same).
38-12CB is AC operated; the 40-90CB requires batteries.
38-12CB: http://www.philcoradio.com/gallery/1938c.htm#c
40-90CB: http://www.philcoradio.com/gallery/1940a.htm#e
Are 40-90 and 38-12TT the same radio? - by morzh - 01-17-2014, 11:50 AM
RE: Are 40-90 and 38-12TT the same radio? - by Ron Ramirez - 01-17-2014, 12:34 PM
There are currently 9483 online users. [Complete List]
» 3 Member(s) | 9480 Guest(s)
