where! 3 and 4 lead caps.
My point is, given that this radio looks to be a late 30's style, that the caps that are in there are way too large for the circuit. I'm thinking that the originals were closer to 8 and 16 uf, and that 120uf total capacitance is going to be much, much too much. Of course, all I have to go by are the pics, and from what I can tell with those is that the radio is similar to one of the Plant A units, with 25Z5, 6D6, etc..
where! 3 and 4 lead caps. - by OldRestorer - 01-17-2014, 06:13 PM
RE: where! 3 and 4 lead caps. - by Jamie - 01-17-2014, 06:21 PM
RE: where! 3 and 4 lead caps. - by BrendaAnnD - 01-17-2014, 06:35 PM
RE: where! 3 and 4 lead caps. - by morzh - 01-17-2014, 08:31 PM
RE: where! 3 and 4 lead caps. - by OldRestorer - 01-17-2014, 08:54 PM
RE: where! 3 and 4 lead caps. - by Jamie - 01-17-2014, 09:26 PM
RE: where! 3 and 4 lead caps. - by TV MAN - 01-18-2014, 12:28 AM
RE: where! 3 and 4 lead caps. - by BrendaAnnD - 01-18-2014, 03:06 AM
RE: where! 3 and 4 lead caps. - by OldRestorer - 01-18-2014, 09:02 AM
RE: where! 3 and 4 lead caps. - by codefox1 - 01-18-2014, 06:40 PM
RE: where! 3 and 4 lead caps. - by OldRestorer - 01-18-2014, 06:56 PM
There are currently 8751 online users. [Complete List]
» 1 Member(s) | 8750 Guest(s)
