Hello from new member
Hi Tim and welcome! I've been with this forum a little over a year now. I came in knowing only enough about electronics to be dangerous. These folks are more than willing to help every step of the way. Kept me from electrocuting myself at least a few times! Even if you aren't working on a radio you can always chime in at Old Ron's Bar and Grill. Always something going on, and you will learn something along the way. It's all good!!! Take care, Gary
Hello from new member - by tim1 - 01-16-2014, 12:21 AM
RE: Hello from new member - by klondike98 - 01-16-2014, 08:59 AM
RE: Hello from new member - by Eric Adams - 01-16-2014, 10:31 AM
RE: Hello from new member - by TA Forbes - 01-16-2014, 10:38 AM
RE: Hello from new member - by hsusmann - 01-16-2014, 10:52 AM
RE: Hello from new member - by Tom Hamilton - 01-16-2014, 02:24 PM
RE: Hello from new member - by codefox1 - 01-16-2014, 05:41 PM
RE: Hello from new member - by gregb - 01-16-2014, 06:08 PM
RE: Hello from new member - by GarySP - 01-18-2014, 03:53 PM
RE: Hello from new member - by PAradiogeek - 01-18-2014, 10:00 PM
RE: Hello from new member - by Eric T - 01-18-2014, 10:28 PM
RE: Hello from new member - by Ron Ramirez - 01-19-2014, 10:40 AM
RE: Hello from new member - by KCMike - 01-19-2014, 04:55 PM
