Philco 30-4003 Tone Control info needed (19B Code 123)
Does anyone have any info on the 30-4003 four position tone control? Im trying to finish up a 19B Code 123 and cant find any info on this control. It seems that little info exists, so I would also like to hear from others who have figured the cap values and wiring on your own.
Any info is appreciated!!
