where! 3 and 4 lead caps.
Hey,
I am replacing all the caps in all 5 radios and have tested 90% of the resistors. One actually crumbled when I touched it.
Thanks for the info
Kirk
where! 3 and 4 lead caps. - by OldRestorer - 01-17-2014, 06:13 PM
RE: where! 3 and 4 lead caps. - by Jamie - 01-17-2014, 06:21 PM
RE: where! 3 and 4 lead caps. - by BrendaAnnD - 01-17-2014, 06:35 PM
RE: where! 3 and 4 lead caps. - by morzh - 01-17-2014, 08:31 PM
RE: where! 3 and 4 lead caps. - by OldRestorer - 01-17-2014, 08:54 PM
RE: where! 3 and 4 lead caps. - by Jamie - 01-17-2014, 09:26 PM
RE: where! 3 and 4 lead caps. - by TV MAN - 01-18-2014, 12:28 AM
RE: where! 3 and 4 lead caps. - by BrendaAnnD - 01-18-2014, 03:06 AM
RE: where! 3 and 4 lead caps. - by OldRestorer - 01-18-2014, 09:02 AM
RE: where! 3 and 4 lead caps. - by codefox1 - 01-18-2014, 06:40 PM
RE: where! 3 and 4 lead caps. - by OldRestorer - 01-18-2014, 06:56 PM
Eico 232 VTVM Schematic
There are currently 9301 online users. [Complete List]
» 2 Member(s) | 9299 Guest(s)
