Philco 45 Volume Control
Does anyone have a good picture of the underside of a Philco 45 chassis? I would like to see the detail of the original volume control as mine has been replaced with something newer and the speaker mounting has been modified and not very well either.
Thanks
Gregb
Philco 45 Volume Control - by gregb - 01-18-2014, 07:40 PM
RE: Philco 45 Volume Control - by gregb - 01-18-2014, 08:23 PM
RE: Philco 45 Volume Control - by OldRestorer - 02-05-2014, 08:07 AM
RE: Philco 45 Volume Control - by gregb - 02-05-2014, 09:45 AM
Philco 91 Tuning Condenser
