Philco 30-4003 Tone Control info needed (19B Code 123)
Youre right- thanks Ron! I didnt pick that up before.
Just curious though, wonder why they show part #52 for each of the two caps and part #53 for the tone control body?
Hard to see some of this stuff without a parts list.
There are currently 5749 online users. [Complete List]
» 2 Member(s) | 5747 Guest(s)
