Stewart-Warner R110 console
When I saw this radio in September, I think price was around $100. Yesterday it was $65. Usually they put the prices up around here, rarely do they drop unless they are on Craigslist.
Stewart-Warner R110 console - by Jayce - 01-19-2014, 12:46 AM
RE: Stewart-Warner R110 console - by morzh - 01-19-2014, 12:56 AM
RE: Stewart-Warner R110 console - by Jayce - 01-19-2014, 01:06 AM
RE: Stewart-Warner R110 console - by jontz - 01-19-2014, 09:19 AM
RE: Stewart-Warner R110 console - by Jayce - 01-19-2014, 01:01 PM
Philco 91 Restore Code ??
Philco 40-120C Restoration
RCA T62 is playing.....
Philco 89 indicator light.
Thank you Rod.  Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM
There are currently 3214 online users. [Complete List]
» 1 Member(s) | 3213 Guest(s)
