Frequency counter
Well, my 38-2670 chassis is completely restored, thanks to you, guys, and it is alive!.
Time for alignment. I bought Eico 315, recapped it as well and calibrated as per their instruction (600 K.C.,1700 K.C, WWV etc.) Looking now for the frequency counter which is also hard to find at reasonable price for the purpose intended with a description other than "as is". Looking at "Data Precision 5740" counter now.Anyone has any experience with those?
Frequency counter - by fields 100 - 01-19-2014, 03:49 PM
RE: Frequency counter - by codefox1 - 01-19-2014, 05:39 PM
RE: Frequency counter - by morzh - 01-19-2014, 06:06 PM
RE: Frequency counter - by Warren - 01-20-2014, 12:51 AM
RE: Frequency counter - by gregb - 01-20-2014, 10:51 AM
RE: Frequency counter - by PAradiogeek - 01-20-2014, 07:04 PM
RE: Frequency counter - by Warren - 01-21-2014, 12:51 AM
RE: Frequency counter - by jontz - 01-22-2014, 06:45 PM
Philco 91 Tuning Condenser
There are currently 6901 online users. [Complete List]
» 2 Member(s) | 6899 Guest(s)
