Philco Phonographs.
Now that I have one, I wonder what was the last year Philco quit making its own changers and switched over to vendors like V-M? Just curious as I also wonder how hard it would be to find a nice Philco Hi-Fi with one of these changers in it. (M24, M26, M28 ).
Philco Phonographs. - by Jayce - 01-19-2014, 06:50 PM
RE: Philco Phonographs. - by Don Lind - 01-21-2014, 03:41 PM
RE: Philco Phonographs. - by Jayce - 01-22-2014, 05:38 PM
RE: Philco Phonographs. - by Randy H. - 01-26-2014, 08:01 PM
There are currently 9904 online users. [Complete List]
» 1 Member(s) | 9903 Guest(s)
