How best to restick veneer
To my knowledge none of the finish is photo finish. Good question though, thanks for asking it. Now I'll make sure I get an answer before I start stripping it.
Thanks for the tip.
How best to restick veneer - by phly guy - 06-08-2008, 01:18 AM
[No subject] - by exray - 06-08-2008, 07:29 AM
[No subject] - by phly guy - 06-08-2008, 04:24 PM
[No subject] - by exray - 06-08-2008, 06:23 PM
[No subject] - by phly guy - 06-09-2008, 05:45 PM
[No subject] - by phly guy - 06-09-2008, 05:52 PM
[No subject] - by exray - 06-09-2008, 08:07 PM
[No subject] - by phly guy - 06-10-2008, 08:48 AM
Re: How best to restick veneer - by Robert - 12-28-2008, 05:15 PM
Re: How best to restick veneer - by exray - 12-29-2008, 08:19 AM
Re: How best to restick veneer - by radiomikee - 01-01-2009, 11:45 AM
There are currently 10140 online users. [Complete List]
» 1 Member(s) | 10139 Guest(s)
