Philco 96 Resistors
Here is a link to philco resistor part numbers which should show the wattage for resistors by the part number. Hope this helps. Warren
http://www.philcoradio.com/tech/resistor.htm
Philco 96 Resistors - by Arran - 01-20-2014, 01:57 AM
RE: Philco 96 Resistors - by Warren - 01-20-2014, 03:10 AM
RE: Philco 96 Resistors - by Arran - 01-20-2014, 03:41 AM
RE: Philco 96 Resistors - by Ron Ramirez - 01-20-2014, 06:42 AM
RE: Philco 96 Resistors - by Arran - 01-21-2014, 12:38 AM
RE: Philco 96 Resistors - by Ron Ramirez - 01-21-2014, 11:53 AM
RE: Philco 96 Resistors - by Chuck Schwark - 01-21-2014, 01:34 PM
RE: Philco 96 Resistors - by codefox1 - 01-21-2014, 03:35 PM
RE: Philco 96 Resistors - by morzh - 01-21-2014, 06:04 PM
Philco 91 Tuning Condenser
There are currently 8985 online users. [Complete List]
» 2 Member(s) | 8983 Guest(s)
