Frequency counter
I have that counter and it seems to work fine.
Gregb
Frequency counter - by fields 100 - 01-19-2014, 03:49 PM
RE: Frequency counter - by codefox1 - 01-19-2014, 05:39 PM
RE: Frequency counter - by morzh - 01-19-2014, 06:06 PM
RE: Frequency counter - by Warren - 01-20-2014, 12:51 AM
RE: Frequency counter - by gregb - 01-20-2014, 10:51 AM
RE: Frequency counter - by PAradiogeek - 01-20-2014, 07:04 PM
RE: Frequency counter - by Warren - 01-21-2014, 12:51 AM
RE: Frequency counter - by jontz - 01-22-2014, 06:45 PM
Philco 91 Tuning Condenser
