Philco 41-610 dial pionter
This thread should be in the wanted Ad's if you want to buy a pointer. many more people will see it there who have lots of extra parts. try posting there or a MOD can move the post.
Welcome!
Kirk
Philco 41-610 dial pionter - by videotechie - 01-20-2014, 01:13 PM
RE: Philco 41-610 dial pionter - by OldRestorer - 01-20-2014, 05:00 PM
RE: Philco 41-610 dial pionter - by videotechie - 01-20-2014, 05:06 PM
RE: Philco 41-610 dial pionter - by Ron Ramirez - 01-20-2014, 08:44 PM
There are currently 10848 online users. [Complete List]
» 2 Member(s) | 10846 Guest(s)
