51-1731 Restoration
Scott
I don't know if the tint what it is supposed to be, but otherwise my hat's off to you, looks snazzy!
51-1731 Restoration - by Scott_Fraser - 01-20-2014, 08:40 PM
RE: 51-1731 Restoration - by Steve Davis - 01-20-2014, 09:44 PM
RE: 51-1731 Restoration - by VntgRads - 01-20-2014, 10:33 PM
RE: 51-1731 Restoration - by morzh - 01-20-2014, 11:35 PM
RE: 51-1731 Restoration - by Scott_Fraser - 01-21-2014, 01:49 AM
RE: 51-1731 Restoration - by OldRestorer - 01-21-2014, 08:24 AM
RE: 51-1731 Restoration - by morzh - 01-21-2014, 12:14 PM
Philco 91 Tuning Condenser
There are currently 8471 online users. [Complete List]
» 1 Member(s) | 8470 Guest(s)
